Raypak versa 405a mv
Old 06-02-12, 07:28 PM
Hello,
I am having troubles getting my heater to fire. The pilot stays lit however, the burner will not fire unless I jump the TH terminals on the valve box. The thermopile is putting out about 380 mv at the valve box, is that enough for the system to function?
I replaced the pilot unit last season but i'm wondering if I have thermopile proporly place in the pilot flame.
I jumped the thermostat, hi limit units (2) and pressure switch today to try and isolate the problem, but that had no affect.
Any help would be appreciated.
Old 06-03-12, 08:23 AM
todrut's Avatar
should have 700-800 mv sounds like you might need to adjust location of generator, can test it with a torch or something.
Old 06-19-12, 01:14 PM
thanks todrut
I got the system to fire. after chasing the voltage around the safety switches, i changed out a few of the connections and it fired properly. I get about 390mv at this point and it seems to operate fine on that.
The burner output appears to be pretty low, so i pulled the burner tray and blew out any debris that was in there to make sure i had good flow. It didn't improve the output. Do you have any ideas on why i'm not getting adequate heat output? Sorry if that is too broad a question.
Thanks
Old 06-19-12, 03:51 PM
todrut's Avatar
possibly orfices are clogged? Low gas pressure? Gas valve not opening properly?
Old 06-20-12, 07:27 PM
thanks again. i will clear the orfices and see if that helps. The Honeywell gas valve is new last summer. is there a way to adjust flow on that unit?
