Cal Spa Hot Tub - Safety Suction Switch
Old 04-20-13, 04:03 PM
My Hot Tub stop working due to the code show, SF which indication there is a blockage of sort for the Intake,( there was no blockage ) I hit the buttons to start the pump, it would go on for a few seconds. I replace the switch and it started up right away. The tub got hot over night, I thought all was well, then when I went use it. I hit the button for the Full Flow and then it stopped and I am right back where I was. I am close to getting a technition in, but would like to avoid that.
Thanks
Old 04-20-13, 04:36 PM
lawrosa's Avatar
Super Moderator
Its probably the safety suction switch. Its located in the suction plumbing line near the intake grate.
Old 04-21-13, 06:08 PM
I did replaced the switch with a new one and it allowed the tub water to circulate over night, but then it stop again. Think the switch I bought could be a a dude.
I can get the circulation to start for 2 seconds, then cuts out ?
Ken
Old 04-21-13, 06:23 PM
lawrosa's Avatar
Super Moderator
Im sure you can bypass the switch to test. NO or NC.......
Old 04-22-13, 08:40 PM
Suction Switch
Hi, so I found that there is a switch at both sides of the pump, intake and out. The out switch I found was actually leaking, put in the old one i took from the other side. It started back up. so hopefully that will do it. Thanks for your help.
Ken
