newbie to the pool game - pump issues
Old 11-12-13, 01:58 PM
C
I am trying to operate my pump obviously at the lowest possible cost to me. I spoke to Pentair and the guy suggested 1100 RPM for 8 hours to run once through for my 15,000 gallon pool.
I have the Pentair Variable speed pump.
Pentair Aquatic Systems >> Pool Pros >> Products >> Pumps >> Inground >> IntelliFlo Variable Speed Pump
Is this good advice? Should i run it lower for longer?
I am in Tampa, FL so I will be in the pool yearly, is once through enough for winter? What should I switch settings for in the summer? Should i manually change the settings when treating (alkalinity, hardness, algae, or liquid chlorine shock)?
Old 11-12-13, 05:59 PM
Received 1,484 Votes on 1,372 Posts
Welcome to the forums.
Quite an improvement from the single speed (3250/3450rpm) pump like I have.
My pool is 24,000 gallons and I run the pump for 12 hours a day. Usually in four hour shifts depending on the weather. No heater so it's only open a very limited amount of time.
1100 rpm is pretty low. I'd almost think that you should be running 24 hours at that speed.
Certainly more than 8 hours. There really is no set rule.
I've set my running times based on overall cleanliness and water quality.
