hydrotemp pool heater
Old 03-13-14, 07:40 PM
Cool hydrotemp pool heater
got an old hydrotemp heat pump.
found a bad water pressure switch so far,now the compressor will start run for a few seconds and urn off. when the time delay resets it will do it again,pressure switch? I have a high and a low pressure switch. I am gonna put my gauges on it Saturday to see if its low on freon. the unit is a discontinued model so calling tech support was useless.
any suggestions?
thanks guys.
Old 03-13-14, 08:23 PM
Welcome to the forums.
Put a volt meter on the pressure switch. You should be able to see the voltage change if it's a pressure issue. Off the top of my head I don't know if you should be measuring AC or DC.
Is there a model number on that heater ?
Old 03-15-14, 05:52 AM
thank for the reply
the model # is FTS120A-1D
when I called tech support he told me it was an old unit.
he didn't have the time to go looking for the info.
I did a google search I had no luck finding a pdf Manuel on this unit.
there is a wiring diagram I am using to check for control as well as normal power through out the
cabinet. I am going over to the house today and check a few other thinng like putting my guages on it it just might be low on gas.
thanks Later.
Old 03-15-14, 10:38 AM
Yes.....I've noticed in the past that Hydro-Temp is a real fountain of information.
