pool pump will not prime
Old 06-05-14, 02:52 AM
Hi Guys, I have a friend with a Sta-Bilt 3/4 horse and it will not prime. The pool is full to the overflow, I have check all fittings nothing loose or cracked. Line from skimmer not stopped up. I removed the cover and the discharge line. Filled the pump and turn it on. It pumps very little but the garden hose supplies more water than it will pump. I have the pump housing separated and nothing is broken or clogged. There is no water leaking. I am at a loss. Please help. Thank You
Old 06-06-14, 07:31 AM
todrut's Avatar
you have checked the impellar? Deep inside it? Have you tried to prime in recirculate? or backwash? What type filter?
Old 06-06-14, 07:33 AM
todrut's Avatar
could also be lid oring, crack in lid, usually it is the male adapter going into front of pump, get loose and sucks air.
