Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Teledyne Laars Series one High Limit question
Old 06-06-14, 06:38 PM
While changing the high limit switches on my old-timer Series 1 pool heater (EPG 325), one of the wells that holds the switches started to leak before I could get the new one back in.
Aren't those high limit wells supposed to be dry or are they wet and just plugged by the switch itself?
Is there a fix short of removing the entire heat exchanger (and replacing (I assume) brass fittings?) The exchanger is in great shape aside from this issue. thanks
Old 06-06-14, 07:03 PM
I'm not familiar with that setup but it looks there are two replaceable flanges with seals. I left you the link to the manual below. The parts pictorial is on page 28. The parts you are interested in are # 26, 27, 28 and 29. It looks like they may need to be replaced when the temperature sensors are.
EPGEPMSeries1.pdf
Old 06-06-14, 07:48 PM
Thank you PJ. I don't think those limits are meant to get wet. I'll going to try a little epoxy in the well before I put the new switch in.
