Need advice on treating a small quanity of water
I rented a garage, and have no running water there. I'm getting a 7 gal water container to use to wash my hands.
My question is, what chemicals will I need to use, to keep the 7 gal of water from growing all the bad stuff ??
This will not be used for drinking water. Only for washing / rinsing my hands. I predict the water will be used up, or changed out about every 15 to 20 days.
If someone can tell me how best to treat this small amount of water, I would be very grateful.
I live on top of hill with low water pressure [city water] and experience frequent outages so we keep several gallons of water on hand. I've never noticed any problems with the stored water even after a few months. If unused we try to change the water out but sometimes forget
The water is stored in clean 1 gallon milk jugs .... so if it's municipal water - I doubt anything needs to be done and if it did, mixing in a cap full of bleach should be sufficient.
I would chlorinate the water just as a preventive. It also helps a lot if you store the water in a container totally opaque to light.
Go to an RV or Marine store, they have solutions to add to holding tanks to prevent bacterial growth. Just add when you fill it up.
