Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Removing control board on Gulfstream pool heat pump?
Old 06-04-16, 12:02 PM
B
Hi, I'm trying to replace control board on my HE110-R-A pool pump and I have removed the bolts holding the old control board, but the board seems to be attached somehow by the LCD screen and I can't tell how to detach and don't want to force it. Any help would be appreciated. Thanks!
Old 06-04-16, 12:40 PM
Received 4,139 Upvotes on 3,717 Posts
Welcome to the forums.
I'm not familiar with that pool heater and the online support is just about non existent.
It would appear that four bolts or screws hold the board in. One the bolts or nuts are removed.... the board should just come right out.
Old 06-04-16, 03:15 PM
B
Thanks for your opinion Pete. I agree, but I have applied a moderate amount of force and the thing won't budge. I'm wondering if they put it on with some type of silicon caulk around the lcd screen or something to make a tight seal. I'll try to apply some pressure with small screwdriver head and see if I have any luck.
Victor
Old 06-04-16, 04:17 PM
B
screwdriver worked, was just stuck at 5 years in the same position. Thanks!
Old 06-04-16, 06:02 PM
Good job. ...............................
