Hot tub: pump #1 won't go to high speed
Old 08-16-16, 12:21 PM
I have a cal cooperage hot tub.
a balboa spa pack and motors.
I change to water in the tub and then the tub went to 110
I fixed that and now my pump 1 will only work on low. when I hit the botton to go into high it makes a noise and stops.
I revised pump 1 and pump 2 wires and pump 1 will work in high.
so I no the pump is ok, but I have looked everywhere online and cant find anything that is helpful
Old 08-16-16, 09:31 PM
Welcome to the forums.
110 what...... degrees.... volts ?
Is this a 240v spa ?
Basically you have a control box failure. It sounds like it may be a relay problem.
You aren't going to find any board troubleshooting help online as normally the board just gets replaced.
