DIY hot tub repair
Old 06-08-17, 02:42 PM
R
Exclamation DIY hot tub repair
Hi PJMax.
I figure after a month of navigating DIY hot tub repair I'd finally post the need for help. I have a hot tub that came with our house. It worked kinda... for a few months after we moved in. I would like to restore it myself. I have detailed pictures of all components. I'm not sure where to start to replace the components or which ones that need to be replaced or just replace all and have a new tub. Help?
Old 06-08-17, 02:47 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
You are here in your very own thread.
Start at the beginning... make, model and year of mfg.
A description of the problem(s).
Old 06-08-17, 03:01 PM
R
Photobucket hot tub album: Hot Tub by Vise Versa | Photobucket
Old 06-08-17, 03:11 PM
R
Thank you.
Make and model is unknown. Model and serial number are completely worn off. Honestly it reminds me of a hot tub my parents had in the mid to late 90's. If hat helps. I added pictures to this obit bucket album. Hot Tub by Vise Versa | Photobucket
Ok. End goal is to have this hot tub back up and running. There are no leaks and it seams to be a decent hot tub when it worked for the first few months we moved in.
Problems are:
1. Jets. Most are missing. I am assuming I can just replace from online or in store.
2. Control panel. Pretty much doesn't work. Jets work only a bit.
3. Heater. It kinda worked when we got it. Struggled to keep above 100 degrees.
4. Jets work a bit. Not much movement.
Old 06-08-17, 03:47 PM
P
Received 626 Votes on 578 Posts
This thread reminds me how much I hate Photobucket and their incessant advertising.
So, do you have any specific questions we can help with?
Old 06-08-17, 03:55 PM
R
I guess where to start?
Internals look to be mid 90's.
Should I start with replacing the control pack and pump?
Old 06-08-17, 04:06 PM
R
Size:  45.2 KBName:  IMG_1532.jpg
Size:  41.8 KBName:  IMG_1535.jpg
Size:  51.1 KBName:  IMG_1530.jpg
