No air coming out of jets in pool
Old 05-05-01, 08:59 PM
Guest
Unhappy
I have a in ground pool and have 3 jets for a little jacuzzi and one of the jets is blowing air and the two don't.Now when i blow on the air pipe all three jets have air coming out and soon i stop. It's back to the same one jet. This problem happening before and i plug the three jets up and old leave came out the air pipe. This time nothing. I use the water hose on the air pipe and i get the 3 jets shooting air bubbles like it should. Need help I need my bubbles!!!!!
Old 05-06-01, 02:13 PM
Guest
Wink
the jets will probably need to be replaced. They use the water in a venturi action to suck the air in thru the jet. if there isn't enough water, or the jet is somehow broke it will not pull the air thru.
good luck
