Help hot tub not working
Received 0 Votes
Was running g great for months but....My hot tub pump will turn on for a few seconds then off then repeats this process until the pump overheats. I replaced the capacitor and the same thing happens. I am not sure if it is the pump or the control board causing the problem. When the pump is running it only works on low speed (2 speed 240volt pump) for a free second then turns off....when I push the jets button to get it into high speed it just stops. I tested the bolts coming into the pump when on and I get 240 on low speed.
Balboa vs500
Not sure on tub model...stickers were removed before I got it.
Balboa vs500
