Spa Pump Wont Shut Off
Old 05-10-19, 05:58 PM
G
pump #2 on my hot tub won't turn off. it is high speed only. i tried disconnecting top side control panel but pump still stays on. had to unplug #2 and let system relearn without it until i can fix it. any suggestions on
what might be wrong?
morgan monterrey spa
aeware by gecko in.xm spa pack platform
in k600 controls
Old 05-10-19, 06:22 PM
Received 1,418 Votes on 1,311 Posts
Welcome to the forums.
What is the year of your spa ?
Old 05-10-19, 07:14 PM
G
Thanks for the welcome!
I bought it new in August of 2009.
Old 05-10-19, 09:21 PM
Morgan Monterey spa
I left a link below. See if that's your manual.
I was looking at pump control. It says with every press of the pump button..... the pumps change and it shows the pump and its speed on the display. Is the display changing ?
2005 - present Morgan spa
Old 05-10-19, 10:30 PM
G
that is my manual. i was able to access the tech menu going thru the k600 top control panel which tells the speed current and phase angle of each of the pumps and accessories. as far as cycling the pumps on and off, pump #2 can't be turned on and off by the control panel. when it's plugged in to the spa pack, under the tub, it is on and stays on until unplugged. i did read somewhere about a relay possibly being stuck inside the spa pack that goes to this pump but i don't know how to trouble shoot that and i was contemplating opening it up to see it that may be the case. what is your opinion of doing this?
Old 05-10-19, 11:35 PM
That's why I wanted to see what the display said.
Technically...... if the relay is stuck..... pump 2 should still engage with pump 1 running.
Does the display change from pump 1 to pump 2 on the display ?
If yes..... then it could be a relay or a transistor that drives the relay.
Post the model number or part number off the control board.
Old 05-11-19, 01:28 PM
G
Aeware in.k600 by Gecko--Topside control panel
https://spacare.com/productimages/pd...in.k600_EN.Pdf
Aeware in.xm by Gecko--Mid-range spa pack platform
https://edc.poolsupplyworld.com/wpdf...data_sheet.pdf
Old 05-28-19, 05:41 PM
G
I was finally able to plug pump one into pump two's connection on the spa pack and it does the same thing, will not
shut off until unplugged. Does anyone know if the Aeware-in.xm spa pack is serviceable or does it have to be replaced?
