How to troubleshoot hot tub not working?
Old 07-09-19, 08:48 AM
C
Received 5 Upvotes on 5 Posts
My 15 years old hot tub does not seem to work anymore. It doesn't seem like there is any life in it. How do I go about troubleshooting this before calling the professional?
Old 07-09-19, 09:13 AM
P
Received 2,008 Upvotes on 1,800 Posts
Start at the beginning and follow the power from the beginning and see where it stops or where you run into something not working. So, is there power on the hot tub circuit? Is power getting to the hot tub? Is power getting to the control box?....
Old 07-14-19, 01:13 PM
C
I followed the power and the power do come into this box underneath the hot tub. After this, I don't what else to test/look next.
Old 07-14-19, 01:51 PM
Received 3,747 Upvotes on 3,360 Posts
Are you running on 120v or 240v ?
Post a picture of the control with that cover off.
Post another picture of the back of the cover. (wiring diagram)
Old 07-14-19, 08:58 PM
C
I'm running 240v. I forgot to take the picture of the controls but below is the diagram. The controls and wiring are on the upper panel and I didn't open that one. I will try to open that one sometime tomorrow.
Something I just found when I opened the panel. When the light in the middle of Tork E101B - 24 Hr. Multi-Purpose Digital Time Switch is off ( I think that means no power goes to the hot tub), I still find powers on the electrical wires that goes into the control box underneath the hot tub. So, at this point I'm not sure if the issue is with the Tork or not. If I turned off the switch on my electrical panel that goes to the Tork then there is no power at the Tork as well as the hot tub control box.
Old 07-14-19, 09:38 PM
Did you confirm 240vAC on the L1 and L2 connections ?
There is a fuse directly off the L1 connection in the control box. Check that.
There is a GFCI type device also shown in the L1 control line. Check that.
Old 07-17-19, 05:32 AM
C
Since, it is using 240v, is it safe to use a $35 Sperry multimeter to test? Thanks!
Old 07-19-19, 01:19 PM
C
Thanks for the help. I measured and it's 240v. However, I found that the GFCI was triggered since the light was lit. I pressed to reset and it works again.
