Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Parallel shaft high torque AC gearmotor issue
Old 10-13-19, 01:03 PM
The gearmotor will stop intermittently during the first 20 minutes of operation, then it runs fine for the rest of the day, but when i try to start it again after its been cooled down; it stops intermittently again. Once warmed back up, it runs fine. Anybody know whats going on? The temps at which its exposed to are average room temperature to start and will get up to 105 degrees when working.
Old 10-13-19, 01:24 PM
Received 374 Votes on 351 Posts
Welcome to the forums.
This is the pool/spa forum. Does your unit have anything to do with these two ?
We'd need a better idea of what you have there.
Maybe a picture....How-to-insert-pictures.
Old 10-13-19, 04:51 PM
Received 230 Votes on 212 Posts
Does the motor quit running meaning it's a motor or electrical issue or does the motor run but the output shaft stops turning indicating a gearbox problem?
Old 10-14-19, 08:02 AM
The rocker switch flips( just replace this, but problem persists), the motor stops and so does the shaft.
Old 10-14-19, 06:13 PM
Sorry..... we still don't know what it is you are working on there.
Old 10-15-19, 05:43 AM
Yes, with the minimal information you are providing we can't help much. You still haven't narrowed it down to a motor or gearbox problem.
