Wiring for new pool heat pump
Old 05-15-20, 11:05 PM
D
Received 1 Vote on 1 Post
Having heat pump installed but want to save on electrician by pulling wire and installing breaker myself. Most likely purchasing a Hayward 140,000 btu heat pump. When pool was installed 10 years ago they used a larger size conduit than needed to accommodate future heater wiring. Itís probably about 100í run from panel to pool heater. Thinking a 60amp breaker, no idea what size wiring, figure solid not stranded. Also would I need a sub panel or just run wire to exterior junction box?
Old 05-16-20, 10:24 AM
Received 1,045 Votes on 969 Posts
Hayward W3HP21404T....... 140Kbtu...... 7.2kw and minimum ckt protection 50A.
Installation manual (pdf)
I would use a 50A breaker.
Using two #8's and one #10 green for ground would be ok. THWN/THHN wire.
Much easier to pull stranded wire although both can be used.
There needs to be a means of disconnect at the heater.
You could use a two pole 60A non fused A/C disconnect.
Old 05-18-20, 04:51 PM
D
Are the 2 #8ís both hots plus a #10 ground? Is there a neutral wire required here? Also if thereís already a ground run to the pool area do I need another one just for the heater? Just trying to figure out how many wires are going through the pipe. Already 4-5 wires going through. And just confirming 50 amp fuse would be sufficient? Any benefit to going to 60?
Old 05-18-20, 05:18 PM
The 8's are hots and no neutral is required..... at least on the Hayward I looked at.
You should confirm that no neutral is required if you get something different.
Typically one ground wire is required. It's size is dependent on the largest circuit.
If you have a green wire.... check its size.
I would use the minimum ampacity required. If you have a trip problem it can be increased.
