Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Hot tub runs with error code fl1 then goes to watchdog
Old 05-31-20, 06:28 PM
B
Replaced temp sensor in J330 jacuzzi. Now it runs with all pumps working for a couple of minutes then goes to watchdog. Any ideas?
Old 06-01-20, 11:10 PM
T
Flow sensor or actual air lock some where. Try removing the filter first.
https://www.thecoverguy.com/backyard...s-information/
Old 06-02-20, 10:24 AM
Received 823 Votes on 773 Posts
Welcome to the forums.
@tribe fan..... good info source there.
The FL1 code is pressure switch open and FL2 is pressure switch closed.
The pressure switch is independent of the temperature switch.
You can download the complete manual at the link below.
2003 Jacuzzi J-330 spa manual
