Dream Maker Hot Tub
Received 0 Votes
Dream Maker Hot Tub
I have a Dream Maker Hot Tub, model X4H-UHS-DMI-GG-F, 120 volt. It heats up perfectly, lights and temperature work perfectly. But when I'm sitting in the hot tub and I press on the jets button, the jets won't turn on. The jets turn on by themselves of course to heat the hot tub, but if I want to turn them on manually using the button it just doesn't work. I opened the metal box where the control board is and checked all of the connections and they are super clean/perfect and tight. I do seem to have to press kinda hard to turn the temp up and down. Do you think I just need a new display or what do you suggest I try first to get the jets working? Thank you for any help!
It does sound like a control issue. My first guess would be the top side control panel but before ordering a replacement I would disconnect it's cable and reconnect a few times to see if that gets it working. Hopefully it's just a corroded connection.
Received 0 Votes
new control panel didn't do it
Well I checked all of the connections, and I bought a new display/control panel and it didn't fix it. I hate to replace the entire board and find out it's some pump problem or something.
What is the part number off the control board ?
Received 0 Votes
Balboa RS80 Part # 22962 Rev. A and then the display panel is Balboa MVP240. The new display panel which I bought has the same controls which I don't think is the issue is VL200 Balboa, I bought it from wildwestpoolsupplies Balboa mini oval heat jacket 4 button 53238.
