Aquaflo Spa Pump Shaft Seal
Old 12-12-20, 01:01 PM
Q
Received 4 Upvotes on 4 Posts
I have a hot spa equipped with an Aquaflo Mod 02615005 water pump on a 1.5HP 230V motor made by Magnetek Century Electric, that I installed back in the late eighties.
The shaft seal has sprung a small leak. Does anyone know where I can buy such a seal? Should I also replace the cover gasket? After taking the cover bolts off, the cover appears that it does not want to come off easily, so I am probably going to have to pry it off.
Thanks
Old 12-12-20, 07:27 PM
Received 3,615 Upvotes on 3,241 Posts
SpaCare has good exploded pump views. You can use that site to get part numbers.
You can also buy a complete seal and gasket kit.
The parts are inexpensive so have everything you'll need on hand.
AquaFlo pump parts
PS-200 5/8" shaft seal kit
Old 12-13-20, 01:19 PM
Q
Thanks, bud, will check it out.
