Cleaning scum from Hot tub
Old 06-20-01, 03:37 AM
Guest
Question
I was hoping some one could tell me a good way of cleaning our hot tub without breaking the bank! I keep spending so much on store baught stuff that doesn't seem to work. We have a lot of scum going around the sides of the tub!!
Thank you.
Old 06-23-01, 08:54 AM
the_tow_guy's Avatar
Received 176 Upvotes on 138 Posts
The first question should be what is the source of the scum?
If you maintain proper chemical levels in the spa and take a quick shower before you get in, you should have a minimal scum problem. Is the scum above the water level or below?
If just on the bare side above the water line, drain some water and then clean with a good household cleaner, i.e. 409, etc. If it's all over and you've tried commercial additives you may have to completely drain, clean, and refill. Good luck.
