My pool equipment survived the Arctic storm we had in N. Texas a couple of weeks ago. I drained it using the plugs on the heater and pump. However, recently I noticed when the pump stops, the water runs out of the system. Luckily, the hot tub level doesn't drop overnight. Additionally, when the pump is operating at a low speed (without the floor cleaner running), it appears to be circulating the air in the system. I clearly can see it from the cover on the pump.
I went to Leslie's Pools to see if they have a recommendation. They told me I need some reverse valve, which they were sold out, but their technicians might be able to get. But the sooner tech appointment is six weeks away. Please note, this is a chlorine pool. The salt generator is disabled. Any help with troubleshooting or advising the kind of valve that I might need to replace would be appreciated. I will try to search online.
Since you are getting air into the system..... as seen in the pump cover.... you need to focus on the four labeled PVC pipes. These four are the intake to the pump. Any other line would leak water out but not allow air into the pump.
Do you know what those devices are on the B and C line.... are they valves ?
Have you checked the pump cover for cracks? How about the drain plugs on the pump case? Some have had success putting shaving cream around suspected leak areas.
For the valves, you could try alternately closing and opening one at a time to see if the bubbles increase. That would help you isolate which line the leak was in.
You won't see a leak on the suction side of the pump. Air will be drawn in. Water will not come out.
Depending on what froze there you could have a break underground.
You could have a cracked valve letting air in.
You might be asking about a check valve but I can't think of how it would help there.
I heard about the potential Valve issue from Leslie's Pools. Sounds like I need to inspect the pipes and Valves for cracks on the intake lines. Thanks for your help.
My 2004 Arctic Spa is tripping the GFI when the heater is called for. If I disconnect the heater the pump runs with no issues. I replaced the heater relay that has blown in the past. The resistor by the relay is showing 33.3 Ohms. Any advice?
I have a Sundance 880 chelsee 2011 and I have no power at the display and the breaker doesn't trip. I have a transformer that goes to the circuit board that says it's supposed to be 12v but it is showing 5 volts. I purchased a new transformer and the new one also said 5volts. Also attached to the transformer wires was the led light panel for the tub so I disconnected it and the transformer then showed 8 volts now the highest I have Read. I have power to everything in the tub and the fuse is fine on the main board. What is causing this? Thank you.
