It has been about 5 years since we 'serviced' our pool equipment. We really haven't used the pool that much but we would like to this year. If I shut all the valves in the system and open the filter basket cover, water still flows out so I must have a bad valve somewhere. I need to replace the sand in the filter and have already ordered new laterals just in case I need them.
When I run the pump and use it in vac mode the pressure is really low. At one point years ago the suction was so good at times the vac almost stuck to the bottom of the pool. Now maybe half of the dirt on the bottom is sucked up and the other half forms a cloud around the vac had.
Last week I stuck a hanger in the area of the impeller and did manage to get a few small leaves out. The pressure went from 10 to about 12 afterwards. So I'm thinking I might try and have a look at the impeller. I would like to have a new impeller on hand in case it is needed. Our pump is an Emerson JJ1002-1 1HP square flanged pump. It is at least 10 years old and maybe 20 years old. I did have it 'rebuilt' about 5 years ago.
I can't find anything like our pump on the internet. Our pump says made in Mexico. Are all 1HP square flanged pumps kind of similar ? Do you think there is perhaps a generic impeller I can use ? Is Emerson the same as some other brand of pump ?
Unfortunately that number only brings up the motor.... not the pump.
I know Marlow pumps.
I would say the impellers are not interchangeable and you may need a gasket/seal kit once the pump is pulled apart.
Hmm - what is the difference between the motor and the pump. Is the pump the piece with the basket ? There are no marking of any kind on that piece. Here are a couple photos of my equipment.
Edit : Is the impeller considered part of the motor or part of the pump ? If I were to remove the 4 screws of the flange should the motor pull away leaving the basket part holding the water ?
Reason: reoriented/resized/labeled pic
I just went out to the pool room. We have an identical pump (except for the four screws) for the spa jet right next to the one I have pictured. There are no markings on it either except for a small piece of hard plastic which says "Fill with water before starting pump". I'm sure that label fell off the other pump at some point.
I'll bet these pumps are old Hayward pumps. I'm looking at google images...
Edit : Just tried calling Hayward customer support - closed for the day.
You should always add water to a pump's volute before starting it.
The water is what the seal uses for lubricant.
This is a typical Marlow pump. It's what I have. Mine is around 30 years old and looks identical.
You can match its parts to yours. The biggest difference is the 2 vs 4 cleanout lid knobs.
The red plugs are for winterizing/draining the pump.
You said you had it rebuilt.... who did it ?
I do mine in the winter when it's not needed.
I have many parts for standard Marlow pumps but they do have some differences too.
I just did a search on "1hp marlow pool pump" and one of the images is this - which is IDENTICAL to my pump. (I should have mentioned the 4 raised plastic bands near the bottom).
Unfortunately - this is from an expired ebay listing with no description.
The guy who last serviced my pump is just getting over covid. We have some friends and this guy also does work for our friends. (These people are ultra careful). He tested negative and shortly afterwards visited our friends. Now three people in that house have covid... I think I'll hold off contacting him for the time being.
Thanks for your help. I think tomorrow I am going to see if I can play with all the valves and see if I can somehow drain the water from the pump compartment. I have one of those cheap endoscopic cameras. Maybe I can get a look at the impeller and see what it look like. If I can get the water out of the pump maybe I'll take out the 4 screws and separate the pump from the engine.
Unfortunately - if I close all my valves and remove the basket lid, water flows over the top of the basket area. Maybe I'll make a post over in the plumbing area on this site on "how to service 1 1/2" boston brand valves".
"The Precision Pump was designed to go head to head with the Hayward Super Pump performance. The inlets and outlets are in the exact same position as the Super Pump, this pump has 2" inlet and outlet, but the pump comes with (2) 1-1/2" reducer bushings to match the Super Pump fittings...."
Oh....ok. So your filter is below the pool water level. If the valves don't seal you'll get a constant flow of water. My filter is several feet above the water level. I've removed all those valves and installed ball vales.
Yes - all my valves are brass ball valves. Problem is they are old (you hear kind of a grinding noise when you turn them) and there are many of them (main drain, surface, pool sweep, spa ...). And all of the tubing is brass as well. I'm ok with pvc but not so much when it comes to brass fittings.
We have been in this house for going on 8 years. We have changed the sand in the Jacuzzi ST24-7 filter once in that time. I think it is time once again as the pool doesn't get very clean when I vacuum and the pressure is very low.
The last time we changed the sand I had a 'plumber' do it. He had me purchase the sand and told me to get two different kinds - a very fine one and another more coarse. Is that, in general, a requirement or can I just get 6 X 50 lb bags at the pool store ?Read More
Hello all. I'm looking to stop being lazy and hopefully get to the bottom of my issue. I should mention I am a noob so go easy on me. About 2 months back I had my pool guy apply a cleaner in the pool (at his suggestion) that helped remove some of the darker spots on the floor of the diamondbrite. It worked pretty well however two spots got much worse in the process (see below). I'm trying to understand what this is and how I might clean it. Or what other recommendations you guys might have.
Also on somewhat related note, I've been trying to clean the tiles behind a waterfall feature I have. It has a white haze and one spot also have a build up of material (Im thinking calcium maybe?). Anyways Ive tried a pumice stone and CLR but no go. Any tips on how to best take care of it? When the waterfall is on its hard to see but not so nice looking when its off.
Thanks all!!!
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210331_183710_80cfe0634f11665c37225e08d21c95245f5eaebc.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210331_183716_bdecf590c21b8ad475f3da320d3fe36ba107f2c3.jpg[/img]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210331_183730_ef8d2228db5137063867b97859ff9a9e8bb534d6.jpg[/img]
Read More
