Pool heat pump question....
Received 0 Votes
Having the pool heat pump looked at does the pisg look normal for a 70 degree day and pool water temp around 65 degrees
lowside was 65pisg around 35 degrees
highside was 205 pisg around 102 degrees
system is r22
I have no clue what Temps the system was running at as far as evap, discharge, vapor... just had the pressures checked.
system is r22
Thread moved to pool forums.
We don't discuss charging pressures on this site.
The pressures aren't usually checked unless the system has a problem as checking an operating system allows some refrigerant to escape.
Is there an operating problem with the system ?
