No power to hot springs sovereign 2 hot tub
Hello all, I recently picked up a hot springs sovereign 2 tub for free, seen everything working before I picked it up, travelled home with it put it in place and it sat there for probably a month before I decided to hook it up, filled it with water wired it up and zero power to the tub, I am stumped is it something small I am missing? Serial number is II1P2072 which would make it a 2012 I believe? Any help would be great!
Welcome to the forums.
Is it a 120/240v model ?
Post a picture of the control board..... How to insert pictures.
#2 and #4 are 240v @ 20A.
#5 and $6 are 240v @ 30A.
# 7 is neutral.
Looks like you may have the supply pairs interchanged although the unit should still work.
Also.... by code.... the ground wire to a spa is supposed to be insulated.
I recognize the power board..... can't see the control board.
You can find your base model and year here.... Hot Springs manuals
# 7 is neutral.
