Running 220 for Outdoor Hottub
Old 02-09-02, 04:12 PM
Question Running 220 for Outdoor Hottub
Does anyone out there know where I can get information on the electrical code for running 220 specifically for an outdoor hot tub?
Old 02-10-02, 12:20 PM
Thumbs up
Old 02-10-02, 01:11 PM
HandyRon's Avatar
Old 02-11-02, 10:46 AM
220 wiring for a hottub
Thanks for the tip on the home wiring site. I was planning on running the the 220 through the attic. Do you know if conduit is required to run 220 in an attic?
Old 12-25-04, 09:15 PM
220v wiring
check with your city, county, and the nec National Ele. Code available on line
or it would probably be a lot simpler to go down to your city building department and inquire,
keep in mind you need to know how many amps. service the spa will require, [ most 6 kw heaters w / spa paks require 50 amps dedicated service ] the larger the amps. the bigger ther wire , also how long the ele. run will be.
steve
