pool leak
Old 03-19-02, 01:27 PM
tcbray
pool leak
I have a concrete pool built in the late 70's with fiberglass panels on the sides. It leaks somewhere! How do I find the leak and what do I use to fix it?
Old 03-21-02, 11:23 AM
demerick
pool leak
XXXXMESSAGEDELETEDXXXX
Forum Posts
Forum topics are not to be used as public bulletin board for free posting of ads, solicitations or advertisements of any kind. When forum posts repeatedly promote a product without discussion and advice to a DIYer, it is considered advertising.
Forum intent is an exchange of helpful problem solving methods and solutions to questions and not public advertisement.
Inappropriate postings not relevent to the intent of the web site or any postings deemed as such by the host, administrator or moderators will be edited and/or deleted.
Policy applies to ALL forums on the web site. No exceptions.
Direct your advertisements to advertisement department. Use "receive advertising info" link provided below.
If you object to policy, contact the Administrator and state your objection.
The "Contact Us" link is provided below.
Failure to comply will result in your being banned from the website.
Web Site Host & Moderator
twelvepole
Old 04-01-02, 05:53 PM
tcbray
pool leak
Would u have any suggestions on how to locate the leak? There are no visible cracks in the structure.
Old 04-03-02, 09:39 PM
KL Enterprises
Lightbulb Leaking
Hi.
Try this simple test.
Place a bucket of water on the top step of your pool.
Make the level of water in the bucket and in the pool equal.
Shut down the pool's filter system for 24 hours.
Check the water levels.
If the water in the bucket is higher, you may have a suction side leak.
If they are equal, your leak is likely NOT on the suction side.
Turn the filter on overnight.
Recheck the water levels.
If it is still level you are seeing evaporation.
If the bucket is higher now, you have a pressure side leak.
After this it is time to pressurize the lines and look/listen for leaks.
