Filter sand
Old 04-12-02, 08:07 PM
mlaaw
Filter sand
How do you change out the filter sand in an inground pool?
Old 04-13-02, 01:37 PM
KL Enterprises
What type of sand filter do you have? Top valve, side valve, slide valve. plastic, metal, brand?
If it has an opening on top only then scoop the sand out by hand until you get most of it. Them flood the rest out.
If it splits in the center then just scoop it out.
Make sure that you use silica sand on refill and have the filter partially filled with water BEFORE you start adding sand.
