Concrete or pea gravel for my HOT TUB
Hello,
I am getting a new hot tub in 2 weeks and am not sure if I should
put it on pea gravel or concret and was wondering if anyone had an opion. I know concret is more expensive. Also I want to put a gazebo over it for shade, any ideas on that or where i can pick up some plans?
Thank You, Chris
Thank You, Chris
Actually the pea gravel could be more expensive, in the long run. Almost certainly the gravel will settle. Then the spa wont be evenly and properly supported and could quite posibly crack.
Check the warranty and installation instructions. They probably state something to that effect, and mention something about voiding the warranty.
