Baja Hot Tub-Need new pump heater
I was given a Baja hot tub without the heater, pump blower set up does anyone know where i can get replacement or used parts the tub itself doesnt leak is in excellent shape Baja has only new and the site sent me to a place that wanted $1800 for replacement i would rather buy a new tub at that price
If I read your post right, all you have is a tub.
What you need is a "spa (hot tub) pack". It does not have to be made by the tub manufacturer. Actually, I think you'll find most hot tub/spas install packs made by specialty companies. All you should really need to know in order to shop for a pack is what type fittings are on the tub plumbing (2" screw-on, etc) and what type power (120 or 240v/15 or 20a). I did a quick check on-line for packs and saw prices from $350-900 depending on the features, size, etc. I would think you could get something suitable for under $500.
Good luck.
Good luck.
