Food that is easy/not messy to transport and doesn't taste bad
When I was driving to work I could take leftovers in a tupperware.
Now that I'm biking to work, leftovers in tupperware won't work since leftovers tend to have inherent liquid and when the tupperware gets tilted, a mess results.
I've been taking hummus/flatbread and nuts and that's been working up until now that I'm getting tired of the taste.
Any recommendations on foods that require minimal/zero preparation, I shove it in a backpack, and get on with the day?
Jerky, packaged tuna, crackers, cheese, any kind of fruit. If you have a microwave at work, the microwavable container options are almost endless.
How about a stuffed Italian bread. Buy frozen bread dough. Roll it flat. Then spread a layer of cooked sausage, onions, peppers and whatever you like. Roll it up into a loaf shape and bake. Then you can cut it into slices, wrap them in foil and their easy to transport.
jerky and ready-to-eat microwave options typically have a greater amount of sodium than i should be consuming given my high blood pressure
I bike to work as well. Turns out I'm bad at making meals for work so I just got better tupperware containers. The glass ones with plastic lids with the gasket that have snaps seem to be the best. I'm also bad at washing things in a timely manner, so once through those, if I have a sketchy Pyrex one that day (where the lid is all warped) I just put it in a plastic bag. The Thai food place here has really good "disposable" plastic containers that don't leak with soup, so I use those as well.
I mostly pack stirfry's because I make them for dinner and can make a ton of food really easily.
Chef's salad with dressing on the side,
dry hoagie or sandwich with mustard on the side,
leftovers put over rice or noodles which soak up liquid.
You could probably also figure out a way to tie a small cooler onto your bike or backpack. It would keep your containers from spilling. Better containers shouldn't spill anyway.
If you have a hot water dispenser at work, freeze-dried food works great. Nice & light, no mess. The pre-made packages are expensive, but you can mix up your own meals if you buy cartons of individual food items.
Following up on Xsleeper, rear wheel luggage rack helps immensely, (makes riding home with a gallon of milk and a takeout pizza workable)
Following up on Rye, and "just add hot water" get a case of ramen noodles from local superstore or asian market, but bring along some thin slices of home roasted rib-eye, brisket or rib meat, and a baggie with mint, shredded carrot and bean sprouts - instant pseudo-pho.
You might also consider upgrading the office cooking arrangements, a thrift shop bagel toaster and rice cooker give you lots of options for a low price.
Soup in a thermos. Those are usually good about not leaking. Or if you have a microwave, bring canned soup, and a bowl. Either wash the bowl at work and leave it there, if you have a sink, or pack it home in a zip-lock bag to be cleaned.
How about putting your traditional left overs in a zip-loc bag and then into the tupperware.
The Zip-loc should make them spillproof and the tupperware (or even some type of appropriate cardboard box) could make them crush/pop resistant.
You'd likely not have to even clean the tupperware after lunch....
Better storage containers. Ziplock brand has a screw top. I use it all the time for backpacking. I start rehydrating my food in the screw top about an hour before lunchtime and lunch is ready just by the time and jossling in my pack. I also bike commute, and sometimes bring frozen soup. By lunchtime it's thawed enough that the microwave is quick.
