Pork tenderloin with vegetables
I usually don't buy pork, but it was buy 1 get 1 free pork tenderloin last fall. I finally made the second one, along with onions, potatoes and asparagus. The pork and tenderloin came out great - the onions and asparagus burnt big time.
I looked at several recipes online, none called for what I assume I should have done - put the onions and vegetables in foil. I wonder what I did wrong. The onions were cut relatively thin, and everything was coated with a bit of vegetable oil.
Anything small will tend to heat up and burn faster. So, cutting your onions thin makes them easier to burn especially if you have them laid out in a thin layer. When roasting veggies for a longer time you can use larger pieces so they hold together better and slow their cooking a bit.
stevek66
voted this post useful.
Many recipes will assume that you have to add vegetables in at different times, so that can be left out of the recipe.
Example- the cooking time for potatoes will vary based on whether they are red, white, Yukon/gold or russet- that's mostly due to how well densely 'knitted' the starches are- starchier takes longer.
Onions take less time than potatoes, and asparagus takes less time than onions.
Generally, the "wetter" a vegetable is, the less time it takes to cook, while the harder 'root' vegetables will benefit from longer, but low and slow, cooking.
stevek66
Yea I'm used to cutting onions small as in stir fries. And not all vegetables are going to cook at the same rate and temperature. If I had a root vegetable like carrots, they probably would have been fine. Next time may be on the Weber grill, getting to be that time of year.
