Door lock not locking
Old 07-22-00, 02:44 PM
Guest
Question
The lock in the doorknob is not actually locking the door. Once locked, if I pull on the knob, the door opens. It appears that the part of the lock in the door that is supposed to go thru the strike plate in the door jam is slipping, but I can't see why.
Any suggestions or is it broken; only about six months old.
Appreciate any help.
Old 07-23-00, 07:36 PM
Guest
Lightbulb
Hi:duf
Based on the problem discription in your posting and the fact that this same door worked fine prior, all you should need to do is adjust the strike plate.
Normal useage, movements of the house and door jam, etc. may have caused the door knob bolt to not fully enter the hole in the strike palte. Adjusting the strike plate should correct the problem.
Good Luck,
TomBartco
Personal Quote:
"When experience and knowledge fail,
often times common sense and wisdom will prevail."
Old 07-23-00, 09:33 PM
Guest
Smile
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by duf:
<HR></BLOCKQUOTE>
Old 07-23-00, 09:34 PM
Guest
Post
I will give your idea a try and thanks!!!
