Removing Weslock lockset
Old 09-11-00, 11:33 AM
Question
I have a front door lockset I am trying to replace (Weslock). I can pry the decorative 'rose' away from the door about half an inch, but I don't see any screws to remove!
Does this type of lock require a special wrench/tool, or am I overlooking the way to remove this?
Old 09-11-00, 05:17 PM
Post
have you removed the inside knob. there should be screws underneath the plate that pop's off please let me know of your progress don,
Old 01-10-08, 08:43 AM
how do i get to the screws
how do I get at the screws
Old 01-10-08, 10:10 AM
Wreck's Avatar
Some locksets now have a retainer. Not visible screws. There should be a little hole on the inside on the knob. It's usually on the side close the the rose. Just push that in with a small instrument and pull at the same time. I use an icepick. I'm sure you dont have one handy so just use a small nail.
Old 01-10-08, 04:33 PM
GlobalLocky's Avatar
It's exactly as Wreck says. The knob has a retainer disc or pin on the throat that needs depressing while pulling the knob. Then remove the rose which will pry off easily and locate the two retainer screws.
