deadbolt extremely hard to trun
Old 10-30-03, 08:30 AM
Our deadbolt lock is extremely hard to open. With the door open the key and deadbolt move freely but with the door closed it is very hard to turn the key. We need to pull the door and turn the key at the same time in order to unlock the door
Any suggestions on how I can fix this.
Thanks
Old 10-30-03, 11:32 AM
The first thing to do is check the tightness of the hinge screws. A sagging door can cause a problem like this.
If the door/hinges are ok then you may have to file the strike a little to allow more clearance for the bolt. Often there will be scrape marks on the bolt or strike where it is rubbing. Never file the bolt-only the strike that is screwed to the frame.
Old 11-14-03, 06:45 PM
WGW
WGW is offline
An easy method of telling where you need to file the keeper, is to cover the bolt with an ink marker and run the lock through the cycle a couple of times.
Open the door and extend the bolt to see where the marker has scraped off, then start filing (the keeper).
