Sliding Glass door lock
Old 02-07-05, 08:54 AM
ged
Question Sliding Glass door lock
I installed a prime-line slide-co lock on a sliding glass door and it works; however, it is very difficult to lock and unlock. The lock info is below. Any suggestions for making this lock work better?
C - 1041 SLIDE GLASS DOOR LOCKSET SET PULL (1 EA)Code: 4819124
Manufacturer: PRIME LINE / SLIDE CO
Manufacturer's P/N: C-1041
Universal Product Code (UPC): 049793010414
SLIDING GLASS DOOR OUTSIDE PULL No need for mortising cylinder into lock stile Notched tailpiece for various break-off locations 4-15/16" hole pattern is offset 1/8" from center Works with Adams Rite, W & F and similar latches Works with other universal type door handles 1 black painted diecast pull 1 keyed locking unit with 2 keys 2 no. 8-32 x 2" Phillips flat head machine screws C-1041 SLIDE GLS DR LOCK PULL
Old 02-07-05, 01:11 PM
Try the lock with the door open. If it still works hard then it something with the lock/installation itself.
If it works fine, then your problem is when the door is shut. This usually means an alignment problem of some sort with the latch. I have had to move latches a bit or bend them one way or another depending on the style.
A door that does not shut all the way due to crud in the track or an out of plumb jamb, caused by settling or poor installation, may cause this problem also. In this case try to shim the latch out a bit to allow enough room for the hook to engage without binding.
