Schlage door knob removal
Old 02-07-07, 08:01 PM
G
I am trying to remove the "outer" door knob so I can rekey the lock. The inner door knob can be removed by pushing in the slotted hole and pulling off the door knob. The outer door knob has a small circular hole, but I can't seem to figure out how it works. Thanks in advance for any suggestions.
Old 02-08-07, 06:54 AM
W
Received 48 Votes on 44 Posts
Door Knob
The outer knob probably will not remove by itself. Remove the inner knob and see if the outer knob and shaft will slide out. Good luck.
Old 02-08-07, 08:25 AM
I
To just pull of the keyed side of the Schlage knob........
insiert key and turn a quarter turn THEN push in on the retainer by the throat and the knob will pull off. You the same method for reinstalling.
Old 02-08-07, 05:56 PM
cuedude's Avatar
Good discription im3rd001. That's exactly correct. Another thing which is frustrating is when the design of the knob is such that you can't get the little cover which holds the lock off from the inside of the knob. For this, I push the face of the lock with my finger, until I can get something under it, then work it around. Even a key will work for this. I've maybe been fortunate, but I've never scratched a knob, nor bent one.
Again, thanks for the super answer.
cuedude
Old 02-14-07, 12:08 AM
G
Wirepuller38, I did just that but still counldn't get the outer knob off to rekey the lock...going to try the inserting key and quarter turning suggestion.
Gilt4tennis
Old 02-14-07, 12:10 AM
G
im3rd001,
thanks for the directions, i will give it a try. i suppose the reason for that is to limit access to key holders.
gilt4tennis
