removing cylinder in schlage padlock
Old 09-28-07, 04:07 AM
I have an old, probably 15- 20 year old schlage padlock, works great but I won't to rekey it, I can get the locking bolt out of the lock and remove the spring but I'm lost from here, there is no screw inside to remove so not sure how the cylinder comes out.
Thanks
Old 09-29-07, 07:39 AM
Some of the old padlocks used drive in pins as retainers or screws that were ground off (Russwin) but not sure for the Schlages.
If that is the case, you would have to drill and have replacement parts to finish the job.
Old 11-07-07, 11:42 AM
After further looking into the lock and cleaning it up I found the screw in the one side removed it and removed the cylinder and rekeyed it and put it back together, worked like a charm..
thanks
Old 11-07-07, 08:54 PM
Glad you got it-thanks for the update.
