help replacing cheap handleset
Old 03-29-09, 03:09 PM
I am trying to spruce up my house before putting it on the market. I decided to replace the handleset on the front door (first impressions count). I am trying to NOT drill additional holes in the door, but I can't find a set where the bottom screw will line up with the existing hole. My old set does not have any kind of identifier to tell me a brand name (I am thinking a no-name builders grade set).
Is there a "measurement" that is standard? Or a term for the measurement from the center of the lock to the screw on the bottom (on mine it is almost 8 1/2 inches).
Any advice would be appreciated!
THanks
Jennifer
Old 03-30-09, 01:32 AM
GlobalLocky's Avatar
Baldwin products make some great quality entrance sets, that are guaranteed for life.
Have a look at the range Products - BaldwinHardware.com
there are product templates that show measurements. Many measurements vary according to style and function
Old 03-30-09, 01:42 AM
The Schlage Parthenon sectional entrance set has an 8.5" distance between the center of the main bore and the bottom screw.
See Schlage - Products
Here is the template to support the product with the measurements http://consumer.schlage.com/products...20Template.pdf
There are multiple brands that will probably be available but if price is a motivator, you might consider the Schlage option as a better fit. (cheaper too)
Baldwin are considerably better quality but are significantly more expensive (as they should be with their lifetime guarantee)
