Handleset for older door
Old 06-19-10, 12:33 PM
Question Handleset for older door
Looking to replace the locks in our house and one tricky issue is the front door. It's got an older one piece handleset on it with an 8 inch long assembly inside the door jam.
So I'm looking for a handleset that will fit exactly inside the existing cutout inside the door. It's exactly 8 inches high.
I had been looking at Schlage, Baldwin and Medeco. Do you know of any handlesets from these brands that will fit my door?
Attaching a photo of the door & lock so you can see what I mean.
I had been looking at handlesets like this but I don't think they'll fit?
Baldwin Handlset
Medeco Handleset
Schlage Handlset
thanks!
Old 06-19-10, 08:50 PM
Just curious, is there a brand name anywhere? If you still have the original key cylinder, it should be there above the keyhole.
1st thing, you have a "mortise handleset" which has a 8" lock body faceplate as shown in your pic; the Schlage residential
handleset is NOT a mortise prep, and so, won't fit in your door.
And while 8" X 1.250" faceplate size is standard for most US mortise lock bodies, as is 2-3/8" backset (residential), the height of the knob spindle hole, thumbturn hole, cylinder hole and thumbpeice hole, varies a bit from one brand to another, so, generally, the larger the escutcheon plates are on the new lock, the more likely they will cover old holes that may not line up exactly.
The Baldwin line, although expensive, carry a lifetime warranty, and have a very wide selection of mortise handlesets.
Many manufacturers have the actual templates you can see online, which shows where the holes are drillied in the door.
Old 06-21-10, 09:04 AM
GlobalLocky's Avatar
Don-Jo is a manufacturer of renovator plates designed to cover the mortise prep in the door edge. You could use 2 push plates on the inside and outside face of the door to cover the old holes. Then just fit any brand of standard prep lock that you choose.
I have done this multiple times for people who want to modernize.
Here is a link to the product page http://www.don-jo.com/catalog/pdfs/p46.pdf
you can get these from most locksmiths but you may have to order them.
