Dead Bolt problem
Old 07-19-10, 07:02 PM
Dead Bolt problem
Hey I need some advice and good ideas on how to fix a problem. I just moved into an apartment and the patio door does not have a bolt lock. I have found that the door knob that is on there can be broken into in about twenty seconds or less and the latch they have put on top is not the strongest either. I have talked to them and they don't want to drill a hole in the door to install a bolt lock but they would put a dead bolt in place of the door knob. That would be fine except that with out a door knob i dont have a way to pull the door open. Does anyone know of a door knob that works as a bolt lock that could be installed without drilling any more holes? Or maybe some other locking device that would be just as safe?
Old 07-19-10, 08:54 PM
GlobalLocky's Avatar
Weiser used to make the contraption you want. I cannot remember the model or if it is still made.
It is a combination entrance set and deadbolt in one unit. The latch closes normally like a entrance set and you can turn the key to extend the latch into a deadbolt.
Gainsborough make a product called the Trilock that principally does the same thing. Although it uses a heavier footprint.
Old 07-20-10, 05:15 PM
Thanks for the help I will look into it. If you do think of the model let me know.
Old 07-20-10, 08:59 PM
Tell them to put a deadbolt in place of the doorknob, using 2" or longer screws to secure the strike plate, and get a small "Sash Pull" from Home Depot (it's just a little grip handle) to surface mount on the pull side, to pull the door closed.....(this is presuming that the door will stay shut on it's own, when the deadbolt's unlocked, just for convenience, when you're home).
The "Weiserbolt" as Global referred to, is, I believe, no longer available, and anyway, I had one once, and it wasn't too handy, for a number of reasons.
You can also get aftermarket surface mounted deadbolts that are fairly cheap & easy to install if you need to keep your knob lock to latch the door closed....again, just be sure to use long strike plate screws.
Old 07-21-10, 06:27 PM
Thanks for your help. I have been looking for the weiserbolt and ever where that I look it is out of stock. Can I ask what was wrong with it? It sounds like the perfect solution but there must be a reason that it is not made anymore. Is there by any chance a lock made my someone else that does the same thing?
Your other solution sounds good as well, I will need to find out if they will let me put a handle on the door. Once again thanks for all the help. And I will be sure to use long screw plate screws.
Old 07-22-10, 01:22 AM
The Gainsborough Trilock is essentially the same thing but uses a bigger installation, requiring additional hole drilling (so the trim fit on).
You may not be able to get in the USA but I can get it from Australia for you.
Gainsborough Hardware - Trilock Series
Old 07-22-10, 07:15 PM
Depends on how you will use the Weiserbolt; Used primarily as a deadbolt, with infrequent unlocking would not be as unhandy as the way I used mine: unlocking the deadbolt in the AM, frequent use as a passage set during the day, then deadbolting at nite.
As a passage set, the ergonomics are poor---you must turn the knob about 1/4 or > turn before the latch begins to retract, then a further 1/8 turn against stout spring action for full retraction. The latch had to be kept greased for good closing action, as the latch spring is, as mentioned, stout.
Also, from a deterrance standpoint, a potential thief only sees what he thinks is a "knoblock" with no deadbolt on the door, so an attempted forced entry might be more likely.
And lastly, despite it's heavy construction, it still had the standard Weiser key cylinder, known to be easily picked open.
Old 07-22-10, 07:22 PM
The trilock would be nice but the owner wont let me drill any new holes so I wont be able to use that one. Thanks for the offer though.
Old 07-22-10, 07:26 PM
I would be useing the weiser lock as an enterence to get in and out rather than going through the builiding to get into my apartment. I dont think that I am going to find one to buy though. Every where I look they are sold out. The Weiser website does not even have them on there. My best option right now is putting the bolt lock in the door knob hole.
Old 07-22-10, 07:44 PM
Well, surely the owners won't object to you putting a little sash pull on that takes a couple of 1/8" pilot holes to fasten it to the door with.....good luck!
Old 07-23-10, 02:55 PM
Check out the Schlage B250 nightlatch. It might be the perfect solution you are looking for.
Schlage - Commercial Security Products
Old 07-26-10, 02:28 PM
I hope they don't mind but they have been weird about the whole situation so I would not be surprised. I guess I will find out after I put them in.
Old 07-26-10, 02:33 PM
[url= - Commercial Security Products[/url]
That look good I will have to look into that one. Thanks
Old 07-26-10, 04:32 PM
That's why we're here. Hope it helps. Please follow up and let us know your progress
