Surface/flush mount deadbolt question
Old 11-18-12, 08:27 PM
Hi, I have an older Ideal Security flush/surface mounted deadbolt on an exterior door. I need to remove it but cannot find any exterior screws, slots or holes to release a cover or any other method to get it off. It is keyed both sides and i do have a key.
See the picture.
ANY ideas would be much appreciated.
Thanks in advance.
Old 11-18-12, 09:47 PM
I got this second hand, so can't swear by it, but there's a small slot or hole next to the inside keyway that, at some point during key rotation, opens up to allow a poke tool to press a release pin that allows the inner turn-knob to come off.
That may in turn, allow the lock's decorative cover to come off, revealing the screws.
Let us know if that's the trick.
Old 11-24-12, 10:45 AM
Talking Got it....
Thanks for that response. You are dead on correct.
There is a tiny (i mean tiny) slot just under and at the right corner of the inside keyhole. When i insert the key and turn it to open, a cover slides to reveal a slotted hole. I inserted the smallest hex key i had and pushed in.....the round cover popped off to reveal screws.The rest was easy.
Thanks again !
Old 11-24-12, 02:01 PM
Good! Now if I can just remember this 10 years from now...
