Problm with a Maxtech entry door lock
Received 0 Votes
Thank you for your help it will be appreciated,
Peppar
If the latch does not retract when you turn either knob, it has not been installed correctly, or it is broken. I think this is a Grade 2 lock, which typically is taken apart by using a poke tool (such as a paper clip, ice pick, etc) inserted into a small hole in the inner spindle, to depress the knob retainer, while pulling out on the knob. The rose trim can then be pried off (some designs require a slight unscrewing motion), to reveal the screws.
The poke hole is usually located in line with the latch, ie., facing the edge of the door. Ocassionally, the poke hole will be located 45 degrees up or down on the spindle, which requires you to turn the knob accordingly to line up the retainer.
Maxtech products are garbage (in my opinion). the handle or knob often does not locate correctly and will just spin on the shaft. This lock needs to be filed in the round file cabinet known as your trash can.
