Trying to figure out how to open this window
Old 10-22-13, 08:25 AM
Question Trying to figure out how to open this window
I'm trying to get my living room window opened to wash the exterior of it (it seems my appartment complex doesn't wash them themselves), but, I've been stuck on how to actually open the said window.
It has a weird lock, shown in this picture:
Name:  2013-10-22 11.17.55.jpg
I'm puzzled as to what kind of key or wrench I need to open this. Could this lock be custom made? I'm definitely not an expert when it comes to this, so, that's why I'm asking for help here!
Thanks!
Oh, and, I also tried using this, but, it simply didn't fit.
Old 10-22-13, 09:10 AM
Received 187 Votes on 174 Posts
The tool you linked has square, four sided sockets. The head in the center of your lock is a hexagon with five sides. Have you tried a standard wrench or socket?
Last edited by Pilot Dane; 10-22-13 at 09:12 AM. Reason: IMG code does not work when spelled with a B
Old 10-22-13, 02:56 PM
Received 25 Votes on 19 Posts
WOW! I learn something new every day. I always thought that a hexagon had six sides and a pentagon had five sides. Also, I never knew a standard wrench or socket was for use on a five-sided nut or bolt.
Quite honestly, the only time I ever saw a five-sided bolt head was on the locking mechanism to an underground utility vault, something that the average person should NOT be investigating. Oh, yeah, the valve stem and cap stems on the fire hydrants in my area are also five-sided to keep the peasants from diddling with them.
Old 10-22-13, 03:17 PM
czizzi's Avatar
Received 9 Votes on 7 Posts
Hmmm.... The sarcasm is strong with this one Obi-wan.
Here is the answer you have been searching for - Custodial locks
https://www.truth.com/products/Comme...ustodial-Locks
Old 10-23-13, 12:52 AM
I couldn't have done it without Pilot playing the part of the straight man.
Thanks for posting that picture of the special wrench. I have seen the window latches in commercial buildings.
Old 10-23-13, 04:43 AM
pentagon... hexagon... what's the difference??? Maybe that's why I have trouble at stop signs?
Old 10-23-13, 07:26 PM
Received 3 Votes on 3 Posts
It looks like a standard socket or nut driver would operate the latch. The purpose of the 2 tits on the OEM tool appear to be so that it will be captured when unlocked, ie., the tool can only be removed once the latch is re-locked.
Old 10-26-13, 07:59 PM
GlobalLocky's Avatar
i would think that the average ratchet type screwdriver with interchangeable screwdriver bits would work well in this situation. Just remove the bit from the driver.
