Question about installing a deadbolt/door knob...
Old 11-02-13, 08:28 PM
I was installing a new deadbolt and door knob and noticed that this part of the lock http://i.imgur.com/GOWNjKh.png (colored in red) is kind of loose because the screws don't really have a lot to screw into since the door is old and has had many locks installed and removed over the years. It doesn't really seem like a problem, and the lock functions fine, but I was wondering if there's anything I can use to like, fill the door in so the screws have something to hold on to.
Thanks!
Old 11-02-13, 11:47 PM
If it's an all wood door...... try filling each hole with a wooden match stick.
Old 11-03-13, 04:09 AM
Longer screws will also work.
Old 11-03-13, 08:33 PM
Longer screws...twice the length of those supplied. If it's hard wood, I'd drill a pilot hole first, to keep the door from splitting.
Old 11-04-13, 10:38 AM
GlobalLocky's Avatar
There is an excellent product called Plast-Aid that is available online. You can use it for filling the holes in wood to allow the repair of screwholes.
I use it for repairing UPVC and waterproofing, creating new moulded parts. i also use it to recreate parts for broken die cast or simply to repair broken diecast.
Search on your search engine and watch the videos. It is only about $20.
Old 11-04-13, 10:40 AM
Another way to resolve this is glue something into the hole like a golf tee or wood dowel (sometimes requires drilling the holes a little larger to get an exact fit for the plug), cutting it off flush and then re-drilling the holes you need.
