Help key stuck in front door
Old 09-16-14, 12:55 PM
Can anyone help, my key I stuck in my front door it is in the downward position and won't turn. It is a upvc mulipoint locking door
Old 09-16-14, 01:30 PM
Can you access the lock from the inside? Your best option is to disassemble/unscrew the lock cylinder from the lock and take it to a locksmith to have him either replace the cylinder or, best case, remove the key.
Alternately, is the key loose or jammed in? if loose but broken off, perhaps with some patience, you can superglue the other piece (or other slim piece of metal to the remaining stub and then pull it out after the glue sets? This is a little risky since any extra glue could just end up gluing the broken stub into the cylinder.
Old 09-16-14, 01:40 PM
Is the door open or shut? locked or unlocked?
Old 09-16-14, 01:46 PM
Hiya thanku for responding the door is shut and locked we are on the outside and can't get into the house
Old 09-16-14, 02:19 PM
call a locksmith to drill it out. about $100 in the US.
Old 09-16-14, 02:41 PM
Got in thanku locksmith it was
