Old Medco double key deadbolt removal.
Ace_77's Avatar
11-08-17, 02:37 PM   #1 (permalink)
Hello everyone. First time posting. Hope someone can help me out. I have an old Medco double keyed deadbolt which I'm guessing is around 25 years old which I'm trying to remove. I've tried to post pictures. Thank you
Donato_'s Avatar
11-08-17, 03:07 PM   #2 (permalink)
You didn't say if you have the key or not. If you don't have it, you probably have to drill through the cylinder.
Ace_77's Avatar
11-08-17, 05:11 PM   #3 (permalink)
Sorry for not mentioning it, but I do have the key!
I was unable to find any kind of set screw. I looked for a small gap beside the deadbolt as well (saw online about someone putting a small allen key in there) but didn't see one. The flanged outer rim of the deadbolt in the picture does rotate with a pair of channel lock pliers, bit it is very tight.
Donato_'s Avatar
11-08-17, 05:31 PM   #4 (permalink)
You should see 2 small holes on the other side. Turn the key a 1/4 turn & insert a small Philips screwdriver. Unscrew the two screws. Remove both cylinders. Then you can remove the side piece.
Ace_77's Avatar
11-08-17, 05:39 PM   #5 (permalink)
I've added some more pictures of the outside of the lock and the edge of the door
Ace_77's Avatar
11-08-17, 06:45 PM   #6 (permalink)
So I was able to find a small circular "spring" on the outer rim of of the cylinder between that and the tapered "shroud". Sorry but I don't know all the proper names for these things. After removing the spring I'm kinda stumped as what to do next.
rstripe's Avatar
TX
11-08-17, 09:03 PM   #7 (permalink)
That wire spring holds the inner cover into the face of the cylinder. Usually, once the wire retainer is removed, the cover just falls off, to reveal the 2 allen tie screws, but after many years, the cover is likely to be stuck to the face. Use a tiny screwdriver or similar to loosen the cover and it will come off.
rstripe's Avatar
TX
11-08-17, 09:13 PM   #8 (permalink)
I can't tell from your photos, but the retainer is used on the INSIDE cylinder, as otherwise the lock could be removed from the outside. The photo is sharp enough tho that I recognize the keyway as "AIR" which was the original patented keyway from the 1960's, so yeah, that's an oldie!
Ace_77's Avatar
11-13-17, 07:06 AM   #9 (permalink)
Thank you everyone for your responses. I was able to successfully remove the deadbolt with your help. Much appreciated!!
