What tool do I need to rekey my schlage deadbolt?
Received 0 Votes
I purchased a rekey kit to rekey 3 schlage deadbolt locks, but I'm missing a tool to remove the key cylinder cap. I found several tools online but none are guaranteed to work with all schlage deadbolts, and mine looks different than any of the locks shown in videos and photos I've found online. See the attached two photos. The cap does not screw off, and what looks like a pin on the top does not depress. The schlage cylinder cap removal tools I've seen online do not look like they'd be of any value as there are no pin holes to grab.
Any help would be much appreciated.
As ThisOldMan stated, they came, they went, I think due to patent infringement with Kwikset's similar design. I would avoid locks with both designs, as they were vulnerable (at least in the initial versions) to certain inherent weaknesses, and reliability issues. IIRC, Schlage used a "Change Key" of a different color when you wanted to re-key it. Somewhere I remember reading about a work-around if you didn't have the Change Key...
These designs are a real Rube Goldburg ingenious invention, using a bunch of tiny precision-cast parts, nevertheless, the made-in-China-cheaply result was more prone to malfunction than your ordinary pin-tumbler lock.
You can still find the blue reset keys. Cut a copy of your existing key onto a blue key. Cut a copy of the new key you want to key to, on a blue key.
insert blue key into cylinder, turn to 11 o'clock, withdraw key. insert new blue key into cylinder turn to 12 o'clock and withdraw.....cyl is now rekeyed
