Old mortis entry lock stuck on the door
Old 10-02-19, 06:32 PM
Hi, I'm trying to remove my old entry lock, but it was stuck on the door. I removed as much as I can. However, I can't get the handle and the thru-bolt caps off. Any suggestions?
Old 10-02-19, 06:58 PM
XSleeper's Avatar
Received 791 Votes on 728 Posts
It may be painted on. You may have to knock the cap off with a chisel. Once you get that bottom screw out, you will probably be able to get the handle off. If it doesn't come off, tap it on the side with a hammer.
Old 10-05-19, 04:21 PM
R
Received 12 Votes on 11 Posts
Send photos if possible....different issues for different locks when dealing with reluctant fasteners.
