The latch portion remains inside
Old 10-13-19, 07:10 AM
The lock portion works fine, but the latch portion no longer responds to the handle, remaining inside the lock mechanism. It can be teased out but appears loose and slides back in, leaving the door unlatched.
Old 10-13-19, 07:15 AM
XSleeper's Avatar
Received 229 Votes on 211 Posts
Time to replace the latch. They are usually available / sold seperately.
Old 10-14-19, 06:42 AM
Thanks. With Andersen, that probably means the whole lock mechanism box. Some it.
Old 10-14-19, 07:15 AM
GregH's Avatar
Super Moderator
Received 13 Votes on 13 Posts
I am addicted to fixing things and if you are also afflicted sometimes the handle mechanism loosens and doesn't properly line up with the latch.
Yours could be very well be worn out but it might be worth a look to see if it can be adjusted and/or cleaned up.
WD-40 is a very good cleaner for such things as it will mostly evaporate after applying.
Flush generously and likely lots of dirt and grime will be removed.
