Front door dead bolt is stuck please help
Old 11-08-19, 10:09 PM
T
The front door dead bolt has a small rod that is stuck the dead bolt is unlocking but the small rod is not can any one help
Old 11-09-19, 03:22 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Small rod??
Going to need a picture for this one!
Old 11-09-19, 03:30 AM
Received 786 Upvotes on 689 Posts
Welcome to the forums!
here are instructions for posting pics - How to insert pictures.
Old 11-09-19, 09:26 AM
XSleeper's Avatar
Received 1,813 Upvotes on 1,630 Posts
Are you referring to a three point lock? Where the rod that bolts into the head and sill will not retract?
Old 11-09-19, 06:02 PM
R
Received 38 Upvotes on 35 Posts
The only "small rod" I can think of, is the small anti-saw steel rod inserted into the end of many deadbolts....I've never heard of one coming loose and sliding out tho. I doubt this is what you're referring to anyway. Is the rod preventing the door from opening? Need better description.
